One month with the Moment
Seanie_230 wrote:
Ok downloaded and installed
The app moves much faster and there is a link button
I can see my V1 but pressing it does not do anything.
Cannot see any of my ML devices only the NL converter.
Anyone else playing with it?
Start an Album on Homemedia touch the V1 icon. Now you will see the album cover and you can skip to the next or previous track and adjust the volume.
Further on you can JOIN the other NL products
NO ML products is depending of your setup an programming the BLC
I have a V1 in a stand-alone configuration connected to a NAS. The new Beoplayer App does not see the V1. Is this correct behaviour?
You need a Moment, Essence or Beoplay a9 to let the Beomusic app work with your configuration.
One could also say:
you need more than one NL product to build a multiroom setup.
How does one program (or set options on) the BLC ?
The B&O support page manual just covers installation ...
Where can I read up on the BLC's details
Stijndc, Thank you for your feedback. This is what I expected.
Dear all,
came home from 2 week holiday and found my moment not working. Tablet battery empty while connected to the socket. NAS server down. Speakers not working. Reconnected everything and moment works now but the tablet battery doesn't seem to charge. How can I see whether it's charging? The little battery sign in the right bottom corner of the tablet is almost empty and flickers sometimes. Anyone any ideas?
JoostdenEngelsman wrote:
Dear all,
Dear JoostdenEngelsman,
Check the charging-progress by removing the back plate on the BS Moment to enter the setup-menu. Tap first on "General", then on "Power" and you should see your "Battery capacity". If the battery capacity won´t change, please try a Pin-reset (about 15 seconds) on the Jukebox until the device goes dark. Place it again on the Soundheart.This should do the trick.
Cheers Beroli
Bought a Moment about two months ago. To anyone who might be considering one, a tip, don't bother and put your money towards something that is properly developed and at least does what it is advertised as doing. Total, total garbage, THE WORST PIECE OF ELECTRONICS I HAVE EVER BOUGHT. in their wisdom B&O updated the app, I now can't use my iPad to search for music, as it only shows half a keyboard on my iPad. Ok, I'll do a full title search using the tablet on the Moment, oh they've fucked that up as well, as it searches after inputting the first letter. Just horrible, horrible, horrible. B&O you should be ashamed. Never will I buy anything that has the B&O name on again, lesson learnt.
I tend to agree. Not a day goes by where I don't experience  a bug or shortcoming, often that was not there the previous day. At present I am getting daily "software update failed" messages. Is there no software? When I press update it says none is available.
A shred of good news the App has an update today which seems to have solved the half keyboard issue. Laughably the update is said to be due to market feedback! Who tests these releases?
