Skiingtrumpeter wrote:
dueno wrote:
You can use the moment only for deezer and tunein radio and an airport expres on the line in for your itunes library.
I have my CD player connected to the Line In at the moment as the track order issue is really preventing me from integrating my iTunes library via Twonky with Deezer etc- what I thought the Moment would do!
Can anyone advise if my problem is still a metadata issue within my iTunes library or is there a bug in the way Twonky is reading it?
Hi Skiingtrumpeter,
at this time, there is no solution for the "tracks-in-wrong-order"-issue.
Unfortunately - this is one of the bigger bugs in the software of the BS Moment. Even if your tracks are perfectly tagged - the moment will mix up the order. If you have Albums with only one CD, all tracks should be shown the right order. But If you have more than 1 CD in a Album and you have it sorted like: Artist/Album/CD1 ... CD2 , the Moment will show the tracks in this order: Track1 (from CD2), Track1 (from CD1), Track2 (from CD2), Track2 (from CD1)... - even if the Twonky-Interface is showing the whole Album in a perfect order. I tried different ways to find a solution.
The only way to overcome this issue is to combine all CD´s of one Album in one Folder (Artist/Album/01 - artist - title.mp3...). Therefore you have to retag/rename the tracks/files of CD2, CD3... with consecutive numbers to the first CD (if the cd1 ends with track 17, you must retag/rename the first track of CD2 to the Tracknumber 18... . That is a lot of work and I decided against this solution. It would be better, if B&O offers a fix for this bug instead of crippling your own (proper) database.
Using Deezer is only a work around but a solution.
When it comes to Playlists, the issue is even bigger. All tracks will be mixed up and not shown in the BeoMusic-App. I can not start a playlist from the BeoMusic-App. If I want to start a playlist, I have to use the BS-Moment-Jukebox instead.
In my opinion, everyone of you should forward all known/ experienced bugs to their dealers and to BeoCare and demanding a solution from them. Even if they tested the Device with a 40.000 track-Database from a NAS/DLNA-Server (as they told me), I can not fathom, why they didn´t recognized this really obvious bug.
Cheers Beroli
