Raeuber wrote:
Millemissen wrote:
Sorry, but that is not what you are doing!
When you choose something to listen to from the Moment or from the BeoMusic app (via the interface), the playback on the connected speakers/connected BV starts immidiately.
This is the beauty of the BS Moment and/or the B&O BeoMusic-app - they are integrated parts of the B&O setup.
However, if this 'magic' is not that important to you, there is no reason for you to change your behaviour.
Just keep on pushing buttons and change apps on a device, that you often have to unlock, before it can be used - it is your choice.
Maybe, when the 'multiroom'-update is rolled out, you will see, what you miss by clinging to thirdparty devices and apps.
MM.
When playing with the Moment it took more time with Moment-Deezer than with AppleTV-IPad-Spotify when I started a song until I heard this song.
Räuber
I would probably have had exactly the same problem as you, if I had tried it.
However - and I know that Beroli won't agree on that - I knew from the start, that this is not, what I should expect from interfacing with the device.
As I have written many times before, searching is not the primary function of the Moment.
The MoodWheel is the primary function. Through using the MoodWheel you feed the PatternPlay function with informations on what you like to hear and when.
Searching definitely is there, but as the second layer in the interface, which was clear to me right from the start. It may be improved soon, but it will still be the second layer.
I did not opt for the Moment for myself exactly for that reason. I am a bit like you = I like to search for the content, i want to hear, and I don't need a device, that serves me with music for the 'right mood'.
BUT I know very well, that this is the way, that a lot of users nowadays want to enjoy music - which is fine.
Those (Moment owners), who want to do some deeper searching, can use the BeoMusic app and - in addition - (soon) control their 'multiroom'-setup from there.
Focusing on a search function on that particular device, would contradict the simplicity of 'moodwheeling' and letting the device serve you through PatternPlay!
The difference between you and me is, that I accept this, and that I salute B&O for making a device, that suits the needs of a lot of people.
You don't accept that!
On the contrary - you curse B&O (and the management) because, they did not offer the device, you want.
This is not a device, that will suit everybody (especially not us nerdy Beoworlders), and it surely is not a 'swiss-knife media player'.
It is a 'music butler', a fine one.
If you like that - buy it. If you don't - leave it.
Simple as that!
