One month with the Moment
My dealer told me that there are some problems with the beosound moment connecting with a nassever.
is this correct?
I have a qnap nasserver and i want to be sure it will work
Nobody with a Qnap?
I guess it is more a question of the DLNA server running, than of the actual NAS model.
Has the Qnap a Twonky server installed, or can you install the version, that is suggested/provided from B&O on it?
I have combined the Moment with a Synology DS214+ and it works fine, even without Twonky or the like. I simply copied my entire iTunes collection to the NAS' media server. Even my iTunes Playlists function well although that took a little more work.
Seanie_230 wrote:
Hi there
The manual shows that it can be connected to a ML TV
Can it be connected to a ML TV but in another room as the manual shows its setup in the same room with speakers connected to the TV
I would like to replace my audio master which is in another room to the TV
Any news from the dealer when you went to see
Cheers all
BLGW - Rekindling the love of ML
Soon you will be able to run the Moment out to a legacy ML system without the need for a ML main system. There will be a USB cable that supplies +5/-5 voltage thought the NL Convertor. Watch this space😁
Yes.
with the beosound 5 it works perfect.
Oh interesting.
Current I have my audio master running its own set of speakers.
I have had a look look at transferring my playlists etc from spotify to deezer too.
I need to work out it the moment can have its own speakers for one room and ML for other rooms.
I have a essence remote in the music room, I wonder if I have an convertor in the music room and the moment connected to my TV.
Can you connect speakers to the NL/ML convertor?
Will a full essence allow speakers to be connected to it and receive sound from ML?
And the bigger question can I take sound from the moment back over the ML to my link rooms.
So many questions that may mean buying it and testing.
The possibilities of network integration are endless.
I think this may be the start of ML disappear
I guess, you should wait for the coming update (and for the 'little-black-solution', that w5bno123 mentioned above).
Many of your question will be answered then.
And we won't have to start every sentence with a 'as far as we now know' or 'it is supposed to be....'.
But -  yes, you can connect BeoLab's to the NL/ML Converter. If you connect an ir-eye, you can use it just like how you probably know from an 'Active Link', and listen to the sound from the sources of the ML-master. N.B. it has a line-in connection as well, that can be used as a local source (a turntable or whatever with a line-level output).
Why?
If you have an already installed ML-infrastructure, you can just keep on using it.
Dear JoostdenEngelsman & dear Chris
could you please point me in the right direction? I created some playlists (*.m3u) by myself, but I don´t see them on my moment. The Moment is showing/playing my musicfiles from the NAS (Synology 412+). My file-structure is exactly the same like Chris described it in his post (even the m3u-File is stored in the same folder), but I have no glue, why it doesn´t work.
I don´t want to use the twonky-server on my iMac, because I would prefer a stand alone  NAS-BS Moment-Solution.
Thank you in advance for your help. 😁
