One month with the Moment
You can use it from Bl3500 also today. I do listen to radio, my music and pattern play thru my bl3500, using my beo4
Can you explain your setup?
Yes.
Today i have connected it thru a delay box (not operative yet) and to a ML/NL converter.
In the ML/NL converter you can either set it up as A-master or Av-master. I set it up as AV- master and then everything works just fine!
The only thing that is not working (as for now) is the volume controll on the Jukebox on the Moment, and when you switch from example radio to TV, it doesn't shut down.
in A master setup, everything works, except when you starts music, radio in a linkroom the master in the room where the Moment is connected starts playing. These things will get a fix in the updated software in May.
And if you have NL and ML product you can just use one of them, and not both as for now.
I am using the Moment just as my BS5/BM5 setup i had earlier ๐Ÿ˜
Normann wrote:
Yes.
Thanks.
When you say that you have connected Moment to the NL/ML, does that mean that you have connected Line out on Moment to Line in on the NL/ML converter?
This is how my system is setup:
I guess the difference is, that Normann has set his Moment to use the NL/ML Converter, and you have set it to use the BV!
Am I right?
It can't work in both situations by now - the update(s) in May will change that.
Probably,
Iยดm just curious how he has connected Moment to the NL/ML Converter.
Hallo,
the Netlink seems to based on TCP/IP connection. You have to use a normal network switch for the connection. One cable for the Moment and one for the NL/ML gateway. I was in the same situation first I wondered if this can be true. But it seems to be netlink over TCP/IP.
Frank
frank2u wrote:
Hallo,
Frank
I guess thats the way I have it setup. See my drawing in my earlier post in this thread.
BeoBoy68 wrote:
We have to wait for a Moment Mk II without software problems and a screen in higher definition. ๐Ÿค’
I doubt there will be a MkII, since the software will be updated continuously.
Regarding screen resolution, do you think it actually looks bad or is it that you think its a bad specification? Just curious.
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
