On the back of my BV10-40...
A picture says it all !
Gregory
Wow....   You really managed to pack loads of stuff there...
What does it look like from the front? Completely hidden, I assume.
 I just ordered my BV10 40" from my dealer, to replace my BV8 32". The BV10 will be mounted on the wall with the bracket that can swing out 45 degrees.
Will keep all my stuff in a sleek bench underneath.
engineer coming next week to fit stb bracket for hd dig box
so should be hidden
malcolm
This is the front. The Horror of the back is not visible of course.
Gregory
Very nice! Nice with the blue speaker cloth, matching the carpet. 🙂
Hiort
I also need to stow away stuff, actually a reelbox which is way bigger that the dreambox on that photo. Thus, I also need a 'bench', what did you get?
redil wrote:
Hiort
I got the bench on the photo. Bought in a store in Stockholm. Its glossy white and hide a Cable HD PVR box, Bluray and a TVIX media player.
Hi Hiort
What have you used to conceal the cables between the bench and the TV?
Cheers
Stuart
futurist wrote:
Hi Hiort
Cheers
Stuart
Just a simple "cable channel" that I think you can buy at any "handyman shop". It had to be a little wider than I wanted, since I needed to fit a component cable in there. Works well.
Cheers
Claes
Thanks - will have to investigate.
