OLUFSEN FORM 1 REPLACEMENT FOAMS
Hello people, i have been searching all the weekend this replacement (pads form 1), and i couldn't find anything. I remember that some years ago i found a dealer from beoworld and another one from ebay, but now anything. Someone could help me? I'm from spain, so i think that the online buying is my only way.
Welcome to BeoWorld!
Discussed a few weeks back here on site ... Sadly, there is no solution. There was some chatter about an attempt at reproducing them but I don't think that got very far -nor do I expect that it will.
Hi, any news on replacement ear pads for form 1 headphones?
Thank you
Arnaldo
I bought new ones from B&O store, maybe year ago. Aren't they aviable anymore?
That's what I've been told by my B&O store...
Too bad 🙁. They could keep them on stock, wouldn't cost much to them... I think...
How about cut them from acoustic foam? Kind used as speaker fret?
In my experience, even replacing with the NOS pieces -you suffer the same issue.
I replaced mine. They sat on a shelf for a year unused. I picked them up and the pads crumbled into oblivion.
The only solution is a replacement using different (than original spec) foam.
Do not waste your money on OEM replacements.
Oh, mine are still ok. Maybe yours were wrongly stored?
I changed mine last time 10 years ago and they became dust in my fingers when last week  I picked up the earphones after a couple years of sleep...
I've heard on the grapevine that an original replacement sponge kit has been located, unopened and unused.
The owner has already spoken to s sponge manufacturing company to see if they might be able to help - so hopefully it may not be too long before a solution is found to this issue.... 😕
