does anyone know if the nuimo remote works with the Playmaker or the essence?
i sent a note thru the website but I didn't get any answer. That sounds bad to me.
any feedback would be much appreciated
regards
andrew
regards
andrew
Get the Bang & Olufsen Essence remote. It will work with Essence and Playmaker and other B&O products and it's a company that will at least answer your questions and has retail shops in case you need service.
Avoid all those kickstarter things that all have "the greatest products on earth" but no service, lousy repairability and at least no sustainability etc.
Uhm, hue works with wireless (HomeKit) so I don't understand why it should be only Bluetooth. Sonos works with wifi as well
I have two of the Remotes I also wanted to control my essence but not had time to play. Was also looking for a way to control the Mlgw
http://archivedforum2.beoworld.org/forums/t/18783.aspx
I just got an answer from the helpdesk.
NUIMO does NOT support Bang Olufsen, it is in their plan but nothing more.
NUIMO does NOT support Apple TV. BUT they are simply waiting Apple approval, they have already developed the interface.
By the way it is on offer at 119£ on Amazon from today.
Is it worth to buy? Difficult to say due to the limited usage. Nest control is fantastic, Sonos is not B&O, Hue, there is a cinetic remote control that works perfectly (no batteries) with 3 programmes.
Any thought?
Regards
Andrew
it was on amazon at 169£. Now reduced at 119£. 30% off.
