So what? It's not the codec that ultimately matters - it's the bitrate. The higher the bitrate the less efficient the compression has to be anyway - and bluray will win out over low-bitrate TV tranmission any day
What TV do you own?
What TV do you own?
Munin,
The word goes that there will be an MKIV mid 2008 with a full HD DVD integrated. I'm not sure about upgrades to MKIII though, my reseller tells me there won't be easy upgrades since B&O aim to change more than just the DVD drive.
The Dane
jonnyb:
What TV do you own?
The codec very much matters. MPEG-2 creates a fair amount of artifacts when scaled up. Besides, Sky HD is transmitted at around 19 kBits/sec (see http://www.linowsat.de/0282/all/0282.shtml) which is more than sufficient. An SD DVD is played back at the same bitrate through a Blu-ray player as a Blu-ray DVD, compressed with the same codec.
Anything transmitted at around 20kBits/sec is going to be more than enough for top-quality PQ.
So, er, what TV do you own?
It's hard to have a discussion when you keep ignoring my main points...
Why don't you get a film on Blu-Ray and compare it with its equivalent on TV, sort your 24fps issue out... compare like with like and then come back to me?
....mr anders(son)
Yes also what I'm told. Dual setup...
The Dane
AT,
I guess that VHS outbattled the DVD in the beginning and you could say the same about vinyl and CD's.
Even DVD users would buy an upgrade.. Either HD DVD or BR...
The Dane
