NOW TV
Hi Mark
I work at the Bang & Olufsen store in Liverpool. I am not an engineer but have enough experience to use the service tool. I did it myself so no cost incurred.
Are you asking about the software because you have a BeoVision7 yourself? If you let me know the Type number I am happy to check the latest software values for your set.
Regards
Opman
Thanks Opman my 7 32 type number is 9334
Hi Mark
Your type number 9334 is a mark3 BeoVision7 32.
Latest software for this version is:
AP sw      30.08 (Part number 8344946)
M2 sw      30.08  (flash)
DVD fep     1.1  (flash)
DSM  sw     3.01a  (part number 8344439)
Depending on which Freeview tuner you have:
DVB t   0.2.1.9     (flashed - no longer supported)
DVB HD  0.1.9.9.0 (flashed or via USB dongle)
I hope this is useful for you.
Regards
Opman
Opman wrote:
Hi Mark
M2 sw      30.08  (flash)
DVD fep     1.1  (flash)
Regards
Opman
many many thanks Opman
Hi I am just about to get now tv box and looking to connect via small jack to rca and connect to my beovision 6 22 will this be a problem ??
