Thanks for taking the trouble to reply
I have the EX87 driver loaded into my Beosystem 3 and using the IR blaster. Like I said the fast forward and reverse works you can even change the speed of wind/rewind, you just can't stop it, once its in that mode. You dont need to press and hold the preset button just press 1 to 4 times depending on the speed you want
Regards
Pete
