I have no sound from my beolab 2500 speakers. They are connected to a beosound 3000 with MK3 powerlink cables. The beosound is working as I can get sound out from the power link socket with a powerlink to RCA adapter. The speakers have got power going to them and were working a few days ago. Anyone have any ideas on what could be wrong.
No sound from Beolab 2500 speakers
Welcome to the forum!
As we've had a chat about the problem already by email, I will add a few thoughts for the benefit of the other readers out there, in case someone has ideas to offer.....
Hi Steve and thanks,
So I have now taken the back off the speakers and tested the transformer. This is putting out 27V AC to the circuit board. I have inspected both sides of the circuit board which looks pristine - anything more is beyond me. The LED is not coming on when there is definitely power getting to the circuit board. I can see that the foam that sits behind the speaker cones has 'rotted' which I expect is normal for foam that must be nearly 20 years old.
I have, of course spoken, to the seller and as I said when he showed them to me at least one of them must have been working because he played a CD for me. The journey home included the the usual hundred pot holes and the suspension on my car is pretty stiff - I guess a component on the circuit board may have been rattled - but both speakers ??
Any recommendations on a good engineer ?
Iain
Since the topic stopped, were you able to fix your problem?
It seems I might have the same problem as you.
The LED lights are not on at all!
Hello
Must be the age then, one of mine 2500 BL's has the same problem. The trafo gives power to the circuit board. I have to check the relay. Does others have the same problem and how did you solve it / point me to the right direction where to look.
I am a gold member but unfortunately I did not find the service manual. Can somebody pls PM me one please? This will help me to solve the problem and I promiss to make a tread here on BW cause it seems other fellow members have the same problem with their beolab 2500
Beolab2500 are included in the Service Manual of Beocenter 2300 / 2500 which is on the site.
Good luck
Marcus
Thanks! now I remember that I saw it somewhere
