No sound BV Avant 32 DVD
Hi
I have a BV avant 32" dvd and when I go in RF the sound comes on for a few seconds and the there is a big crackle and then no sound,
but if i go in via scart or RCA the sound is ok, and my BS3200 also works via the link system.
Any ideas?
Regards
Steven
Try using scart and digi coax.
Is it a new TV to you? Sounds as if the wrong type of PAL is selected. You should be able to change this via the service menu - Pal I is number 16!
