i‘m having some trouble with 2 devices, having the same problem, a Masterlink-Gateway and a Beosound Essence MK2.
Both devices show the s/n 00000000 in its firmware.
They are not found by the B&O-App for setup.
Does anybody know if there are batteries inside (like cmos-batteries in pcs) that could be the cause?
In general both devices seem to work correctly, the essence can be used with bluetooth, dlna or airplay without problems.
MLGW can be configured completely and is found by the Beolink2-App on ios.
The web interface of both devices can be accessed and used completely.
The essence does not upgrade the firmware to the latest, i think because of the missing s/n causing problems in identifying the hardware online.
Manual software update is not possible as B&O does not give acces to the firmware-file.
Has anybody had the same or similar problems with these or different devices or knows where to get the firmware files?
Hope for some useful hints, thanks in advance
