No DVD2 - No Beomedia 1 - No Bluray
Since BO should not ever have an external bluray player, could I buy a sony or a panasonic dvd bluray player and recorder that are fully compatible and useble with beo 4 or beo 5?
Yes you can. But be sure to ask your dealer which one to buy. Then your dealer will see to the BeoVision has the correct software to operate it correctly.
