Missed that one! thanksI used the turntable icon for turntable sources
NL/ML Converters feeding the B&O addiction!
Haven't played around with MLGW and source commands but looking in the link documentation it seems that the MLGW should be fit for this kind of setup as well and this is what it states around setting it up from BV10. I was primary looking for verification to be able to handle the source commands.
CMDS. TO MLGW (Master Link Gate Way) can be ON/OFF
- Can be set ON for enabling reroute of all LIGHT and CONTROL commands from remote to MLGW.
- It is recommended only to have one product in a room with this setting to ON
- Three or more products in a room can cause fail on ML
Normal 0 false false false EN-US X-NONE X-NONE
Wow!I've done the same! I used the turntable icon for turntable sources.
