NL/ML Converter not working, hoping those of you with more experience can help.
My setup is as follows:
BS9000 (with BL8000 directly connected) has a ML connection directly to NL/ML converter.
NL/ML Converter connected to Apple Airport Extreme.
BV11-55 connected to Airport Extreme.
BS9000 standalone works just fine, BV11 works fine, including Webmedia etc. so pretty sure the connection between BV11 and Airport Extreme is fine (Youtube streaming from iPad fine, BeoRemote app works etc.)
The BV11 also definitely 'sees' the NL/ML Converter, it allows me to select it in the Product Integration B&O Connect submenu.
Yet when I select AV > Radio / Cd etc. on Beo4 I get a screen that displays Radio From Beolink Converte NL/ML and then after a short while it says Failed... Grrrrr...
I once or twice had it showing Connecting (in lieu of failed) but that also changed to Failed after 30 seconds or so.
Some thoughts,
Do I have to connect the equipment in a specific sequence?
Do I have the turn the bits and pieces on in a specific sequence?
What is the function of the reset button on the NL/ML Converter? (If you press and hold, the small green Light goes dark and then flashes red once - if I release it changes back to green. If I keep holding it flashes red twice, three times etc. does that make a difference?)
Should the BV 11 / BS900 be in particular option settings? BV11 currently Option 1 and BS9000 also option 1 since although technically in two rooms it's an open plan environment so any keypress on the remote is seen by both.
Any thoughts?
PS. The Airport Extreme is set up as a router (i.e. it has DHCP active and issues IP's handles NAT etc.) - direct cable connection from the WAN Port to Internet. I assume this is correct - saw a diagram to this effect somewhere on this forum.
