NL/ML Converter issue
Hurray, It's a micracle! Everything works now 😁 The converter updated itself when reconnected to the BV11. Thank you so much!!
Then I will stay on my iPad futher on 😉
I still have the same problem that you had. How do you exactly update the software of the NL/ML converter? Is there a way to see what software version it is running?
I found it :)
