The converter gets (if it is set as default) an IP adress. You should be able to find it on your network.
Connecting it directly to a pc is one way (as Vienna wrote).
You could also (if all is connected to a wireless router) do the following:
- Open the Internet Browser on the iPad/iPhone (‘Safari’).
- Enter ‘BLC-’ followed by the BeoLink Converter NL/ML serial number: BLC-XXXXXXXX.local.
The username and the password is by default 'admin' 'admin' (hopefully not changed?)
Now you can access the userinterface.
Under 'tools' you can see the softwareversion and update/set to autoupdate.
NOTE: it is recommended from Bang & Olufsen that a NL network ( including the converter) is set up wirh a seperate router as a subnetwork!
Greetings Millemissen
