Hi Frog,
Yes, one issue from using a direct cable connection instead of the NL/ML Converter is that the source buttons may not always match the actual soruce being used. However, I would personally see the c. £600 saving as being a worthwhile trade-off - this could potentially cover the cost of a pre-owned pair of Beolab speakers for a link room.....
Hi Martin,
I haven't tried the Almando switch myself so I can't comment on this. However, if this works well and suits your needs then this is probably best left in place. If you hadn't already purchased this then I would probably have suggested linking the Beomaster 5 digital output to the speakers and the Eclipse RJ45 output to the Powerlink input of the speakers, which should mean that the Almando switch may not be needed. This will still give you music from the Beomaster 5 to the link rooms and both music and TV sound in the main room.
Kind regards, Steve.
