I had noted on the BLC the option to assign a primary and secondary device and I thought you meant that - I'm a bit fuzzy as to how to assign these correctly, so just left them as NL/ML Converter. It hadn't occurred to me to look at the NL products in the App itself though.
I'll look into the options for the Moment/Essence/A6/M3 on the App and see if that sheds any light on things.
Thanks again.
I think you're getting much closer to the solution. You definitely have to assign primary and secondary devices to the Moment/Essence/A6/M3, etc., in order to access these sources FROM that device.
It's my understanding that assigning primary and secondary devices in the CONVERTER setup is mostly relevant if you are having speakers connected to the converter and want to access other NL devices on the converter's speakers.
