I need to purchase another 32" BV8 (this one for my office); any news on when B&O might be considering putting a newer LCD panel (with higher flicker rate / LED backlight / etc.) in this TV?
TIA,
Mark
TIA,
Mark
Allow me to add a question on the same topic (BV8): does anybody know if you will be able to add a DSS module to the 40" version of BV8 (apparently introduced during the Spring of 2009?)
Many thanks.
Klaus
The BV8 with 40" is supposed to get surround, might be optional though.
For the updated LCD panel for the US, nothing is rumored plus I would think they would sell off the older ones first. They did the same with the BC2 when it got a minor update.
If you are after a 2nd BV8, there is supposed to be an update to the european BV7 32" some time soon. I am hoping this one would get to the US then, but again nothing is rumored for us here so far. That might be interesting for you as well, I will certainly consider it myself.
Cheers
JK
P.s. @Beonut, if you are still using your ATV, take a look at my boxee.tv posting in the US section.
