Newbie : how to connect Beocenter 9300 to Beovision 7-55 ?
papas_spiros wrote:
Please for your advice on how I can connect 6 speakers to my BV 7-55 MKII. (I have not install it yet).
2 front (Beolab PENTAS) 2 back (Beolab 8000) and 2 Beolab 3s in the "middle".
+ sub (Beolab 2) + Beolab 7-2 center.
Asking since the TV at the back has 5 powerlink connections (not 6)
+ 1 for the Sub + 1 for the center.
Thank you all in advance.
Hello Papas_spiros, as the PowerLink cables carry two signals (normally L+R) it is possible to connect two speakers to one PowerLink socket. This can be done by using a splitter or by daisychaining two speakers (when they have two PowerLink sockets - beware, the 8000s only have one).
Make sure that of the two speakers connected to one PowerLink socket of the BV, one is set to R and the other to L. You can then later in the menu assign the roles to each speaker (front L&R, surround L&R, rear L&R) and set their volumes and distances.
Hope this helps! Johan
beopaul wrote:
I’m pretty sure BC9300 is also Masterlink. The BC9500 which came before it was Master Control Link.
No, BC9300 is MCL. A converter is needed.
https://www.beoworld.org/prod_details.asp?pid=411
Johan wrote:
papas_spiros wrote:
And it could very well be that the 'CENTRE 1' PL connection can also just be used in the same way as the 5 others, making six available in total. Good luck
Much appreciated Jordan.
I will try your clearly described steps.
Thank you!
Spiros.
Thank you!
Spiros.
