Newbie here with some existential issues.....
Iggy wrote:
Thanks for the quick answer!
And so that I am clear about how each product works, couldn't the Core (or other wifi streamer)¡, connected to the AUX out of the BS9000, also do the job?
Thanks again!
I have been through this recently.
I started by connecting my BS9000 to my A9 via Line in. This worked well, but could not multi room around the house.
I now have a core connected to the BS9000 and then wireless to either the A9 or one of my other products. The multi room works well and the only issue I have is that when I start a cd it doesn’t trigger the core (mk 1) and I have to use the app to start the A9 up. I haven’t tried a converter so not sure how well that works.
That is odd.
All devices should have line-sense (= start up, when signal arrives).
On my M3 it works as should be.
Ah....just worked out I can touch to join......thank you.
