NEW YEAR HELP
Hello All
When i have had new years partys before i just took my beosound 3000 or 4 into the kitchen and hooed it up with powerlink to my computer and beolab 8000 and lab2 but now i have the computer with beoplyer and no beosound
how can i connect it up to work propery for new years and control the volume wiht the computer
thanks
is there a convertor cable of some sort for headphone jack to powerlink that i can buy from my dealer,
how will the speaker know to come on as headphone does not contain on off pins???
If you use the Line in socket on the speakers, they recognise when music is playing and switch on automatically. The Beolab 2 could be a problem.
yeah i see the line inputs (phono) on the lab8000's but no input on the lab 2 hmmmmmmm dilema, anyone ot a solution to this?
yeah i coudl forget the lab2 but i do love bass and it will be mostly dance music
I use a B&O cable with a head phone jack on one end and a power link on the other to connect my ipod/computer/etc... to a BS9000.  If you can connect that to the 3000, that would work.  If you're looking to connect directly to the speakers (I have a BL2 connected to 2 BL8000s), I haven't tried... but I would be willing to give it a try if you really want to know the answer.
-Rob
