New WISA SoundSend 7.1 AudioTransmitter
If one is satisfied with 5.1 sound via wisa wouldn’t the LG tv C9 etc be able to do this standalone? Or does LG wisa only offer stereo?
Further, I am curious as to learn if someone has tried any of these setups with BeoLab Wisa speakers connected directly to LG television.
E.g. master volume, can you use the LG remote to adjust this or will you have to find your smartphone and use the app?
BeoMedia wrote:
Further, I am curious as to learn if someone has tried any of these setups with BeoLab Wisa speakers connected directly to LG television. E.g. master volume, can you use the LG remote to adjust this or will you have to find your smartphone and use the app?
I contacted the company months ago as i was going to try it with my Sony OLED and 18s and 3s to see what it does.
They don’t have a distributor here in Australia. When they do, I’ll get one.
Has anybody actually tried this device?
Or is it vaporware?
Yes, I have this, and it is simply a marvellous and very reliable, no drop-outs like I had with the B&O transmitter and very simple to set up with a multitude of options, It has also just had an update, I am presently running a 4.1 system. I have a pair of Beolab 18 for the fronts and a Beolab 19 for the sub and the rears are a pair of Harman Kardon Citation surrounds incredible small satellites that work perfectly with the Beolabs and Soundsend, and listening in Dolby Atmos in Dolby Vision is simply incredible, for for the price I highly recommend the unit, I have the Soundsend connected to my Hisense tv oled again an incredible screen which has a facility on it to have the sound only and blank the screen, I also stream Spotify and saved music on my tablet and phone as well as watching Youtube musicagain quite superb.
The only item I am after now is a centre speaker, and I am thinking about getting another pair of the Harman Kardons although only needing one.
