New WiSA Ready Standard - 2019 LG OLED and NanoCell TVs
Vince,
1. The Axiim LINK has a DSP to perform the audio functions like bass management, EQ, audio mixing, etc.
2. The LG TV only allows you to use WiSA Ready or the TV speakers but not at the same time. Also, honestly you wouldn't want to use the LG as a center because the quality is nowhere near the performance of the B&O speakers.
An alternative is you can buy an Axiim WM5211CS center channel and we have many customers that do this.
3. This is a great question. I'm not sure if ARC works while WiSA Ready is enabled. I will check today and see.
Thank you,
James
Yes, LINK supports 5.0 configuration and will redirect the content to the main L/R channels.
Hi James any further info on the last point thanksVince, 1. The Axiim LINK has a DSP to perform the audio functions like bass management, EQ, audio mixing, etc. 2. The LG TV only allows you to use WiSA Ready or the TV speakers but not at the same time. Also, honestly you wouldn't want to use the LG as a center because the quality is nowhere near the performance of the B&O speakers. An alternative is you can buy an Axiim WM5211CS center channel and we have many customers that do this. 3. This is a great question. I'm not sure if ARC works while WiSA Ready is enabled. I will check today and see. Thank you, James
Vince,
I just checked and the LG TV requires you choose between the WiSA and ARC so you can't have them both on at the same time.
-James
Are there other TVs that would allow me to use wisa with your solution, while at the same time allowing to use either the tv speaker as center or the b&o stage?Thanks!Vince, I just checked and the LG TV requires you choose between the WiSA and ARC so you can't have them both on at the same time. -James
Right now the only LG is the only TV certified as "WiSA Ready". It's a great start but we definitely would like to see more TV manufacturers on board. In the mean time you can use the Axiim Q UHD Media Center with any TV. Here is a link,
Hi James would this be compatible with the BO sound stage?Thanks VinceRight now the only LG is the only TV certified as "WiSA Ready". It's a great start but we definitely would like to see more TV manufacturers on board. In the mean time you can use the Axiim Q UHD Media Center with any TV. Here is a link, https://axiim.com Thank you, James
