New version om MLGW software
Hi!
There seems to be a new version of the MLGW software http://mlgw.bang-olufsen.dk/source/source/
Anyone that have some information regarding this?
improvements and new features in software 1.61a
New features
Possibility of running up to 4 different device drivers of any kind at the same time.
  improvements
  1. After a period of normal operation, the commands from MLGW starts acting on different televisions than originally programmed
  2. If using a Custom String with the value \00, the string will be truncated from this value at power dropout and after reload from file
  3. If Lutron HomeWorks is disconnected from and reconnected to the mains, MLGW will no longer detect events in the Lutron system
  4. MLGW serial number set to 00000000 after downgrading software from V1.50
  5. MLGW locks up when using the button Upload text file
  6. The television continues to adjust volume up after releasing button on iPhone
  7. MLGW resets when receiving multiple commands from RS232 .
OK, thanks! Do you know if it will be possible to control the Beosound 5 Encore from the mlgw even if it doesn't have masterlink? Or will there be some replacement product/new HW?
beosound 5 encore is "stand alone" then launched then with software upgrade and later comming Beonet/ML interface
it can be integrate to other ML products
/Tompa
Does this mean that mlgw will be able to control beonet products?
Does anyone know about the new MLG  MK3, I understand that soon will be available in stores ,at a lower price???
Interesting, anyone with some more information of the included functionality?
"Lower price" is not a Danish word! 👍
No one with some information regarding mlgw v3?
