Ok then, a few comments: First, these sound awesome. I can't get enough. I might still be biased, and I wish I had the opportunity for a side-by-side comparison (or blinded comparison!) with the H9, but I don't. But I did listen to the H9 quite a lot for a week recently, and I do believe that the H9i is even more transparent, but with even deeper and tighter bass. Best bass I've heard in headphones, not that I've tried every pair out there. I'm looking forward to reading the first reviews.
They are similar to the H9 to operate. The slider button works in the same way. However, touch gestures function slightly different to accomodate transparancy mode. If I remember correctly you would swipe up to engage ANC on the H9, and swipe down to turn it off. On the H9, swiping down toggles the ANC on and off whereas swiping up toggles transparancy mode on and off. Transparancy mode is quite cool. It's like not having headphones on at all. I have trouble thinking of a user scenario where just sliding the headphones off the ears wouldn't be just as good an option, but I still appreciate the tech factor. If it is really cold outside, and you don't want to freeze your ears but still need to hear what's going on around you, I suppose.
I can also tell that the ANC works better now. I can't compare with Sony or Bose as I haven't tried theirs, but this is way better than the H9, especially in midtones. The H9 did ok with low monotone sounds I thought, like the sound when sitting on a bus, but the H9i removes more of the spectrum. I'm travelling on monday, so I get to try them on a plane then.
I like to listen to music loud, and I thought the H9 was a dissapointment compared with my old H6 in that respect. With the H9 I would always wish for the music to be just a little bit louder. Not with the H9i. These, as far as i can tell, play considerably louder than the H9. I've had a few magical moments listening to music really loud with the ANC on, right when the music stops. I've been unable to tell what's more impressive, the awesome loud but clear music, or the instant and complete silence that follows.
The proximity sensor works well too. It takes a second to register that you have taken the headphones off, so you leak sound for a second of two after taking them off, then it stops. Resuming when you put them on seems instantaneous, though.
That's it for now, I suppose. I'll be looking forward to reading what others think about theirs as well. It would be incredibly cool to read about if anyone is in a position to do a blind test on the sound quality of the H9 vs H9i.
-h.
