new to beo world
hi everyone, writing from portugal. an old danish friend just gave me some B&O items, witch I will discribe:
1x beosound ouverture
2x beovox cx100
2x beolink passive
1x beogram 7000
1x beolink 1000
1x beo4
1x B&O ir receiver
1x master link cable
2x speaker cables 2din
 my question is, how in the world can I set this to play in a more simple way. if possible just the beosound ouverture and the beovox speakers.
thanks in advance
Hi & welcome to Beoworld
Simplest way would be Ouverture >Masterlink cable>Beolink Passive>2dinspeaker cables>Beovox CX100
It's worth pulling the fabric frets off the CX100 to see if the cones have deteriorated. This is very common and will effect the sound but there are repair kits available.
It would actually need to be Ouverture >POWERLINK cable>Beolink Passive>2dinspeaker cables>Beovox CX100
Or else you would need the IR Eye also connected to the BeoLink Passive in order to activate the CX100 speakers.
In short, MasterLink is generally used to connect speaker in a different room to the main audio
Actually the BL Passive would have the ir-eye - if it is complete!
Apart from that, I agree with Tayne:
Use PL-out to PL-in and connect the speaker cables and powercord.
BUT - in the list above there was no PL cable mentioned!!!
So the advice from Stonk might be the one to follow.
In that case the Ouverture should be in option 0.
However this would mean, that you can't activate playback from the Ouverture.
All in all - my advice would be to buy a (short) PL cable and do as Tayne described.
Maybe some day you/jpff later could look for a couple of active/BeoLab speaker to connect directly to the Ouverture. The BL Passive, the CX100 and the MasterLink cable could then be used for making a linkroom :-)
@jpff - if you now are confused, please do write again to confirm, whether you have the PL cable and/or the ir-eye.
Enjoy your gift.
Edit!
I just noticed that you have 2 (!) BeoLink Passive - that's even better ;-))
Does '2x cx100' mean 2 sets?
I don't have power link. Can i use any 8pin male connector. But i do have the IR . Have to take it slowly because I'm so very new to this.
Yes,I have two beo passive and two cx100 speakers,not two sets ( i wish) 😁
Oops, sorry - it's long time since I had a similar setup
To get things going best invest in a PowerLink cable - length depending on the placement of the Ouverture and the BL Passive (the amp without the ir-eye connected).
Be sure to get one of the fully wired PL cables, otherweise the amp/the BL Passive won't turn on. Best tell the B&O dealer what the cable will be used for.
Alternatively contact 'Steve at Sounds Heavenly'. He is a sponsor of this site and will be happy to assist you and sell you the right cable.
P.S. But do think of making a second room/linkroom, since you already have most of, what is needed for that.
If you have a spare pair of passive speakers, you are good to go for that also.
Thanks a lot. That's what i will do. Even if money is not exactly pairing with me at the moment,i think its worth the effort. But for the time being the living room will be more then enough to hear the beautiful B&O sound. Be free to give me inputs on my quest
