New Speaker Connections
Hi everyone,
Just another quick question.  Could anyone shed some light on:
  • If all existing speakers in the B&O range will likely change to RJ 45 in lieu of powerlink
  • Or is it just new speakers a la BL12 that will feature the new connection
  • How will this affect if you would like say a BeoSound 5 Encore (i know Paul you're not a fan lol - but I am :-) ) and want to connect to the new connections.
Thanking you
- Michael.
There are allready cables with RJ45 in one end and Powerlink conenctors in ther other end. Also there are third parties adapters comming (if not allready avalible).
I guess they will change it to RJ45 connectors when they are making revisions of the existing equipment along the way.
Also the Beoplay V1 also has the RJ45 connectors
Michael wrote:
Hi everyone,
Thanking you
- Michael.
Hi Michael,
I understand from speaking to staff at Struer recently that existing master products (eg. TVs and audio systems) and speakers will continue to have 8pin DIN Powerlink sockets fitted until they are next re-designed or removed from production. All new products (including a very interesting one due the next couple of weeks! 👍 ) will be released with RJ45 sockets for both Powerlink and Line input (where applicable).
B&O produce cables for these new products (which currently include BeoVision 12, Beolab 12 and BeoPlay V1), plus I have had special adapters made to allow easy conversion between traditional Powerlink and the new RJ45 connections (please see my sponsor link below for more details). Confusingly, B&O also refer to the new RJ45 plugs as Powerlink, so it may not always be apparent when reading their product details exactly which sockets are fitted. I am always happy to help if you need any clarification.
To connect between "old" (ie. 8pin DIN) Powerlink and "new" (ie. RJ45) Powerlink, you just need a normal 8pin DIN Powerlink cable and then clip on a DIN to RJ45 adapter at the end where the newer product is fitted, so this allows for easy connection between old and new products such as Beosound 5 Encore to Beolab 12.
It also makes it easy to change from an Avant or Beovision 7 with older Beolab speakers to a V1 or Beovision 12, without needing to change any wiring - just clip on the new adapters and plug them into the TV.
Hope this helps!
Kind regards, Steve.
Thanks Steve
An excellent post as per usual. Can't wait for the new speaker announcement.
Three cheers to Sounds Heavenly :-)
Thanks Michael!
Although I'm sworn to secrecy about the new product, I didn't say it was a speaker.........  😕
Cheers, Steve.
Bosscom carries several cable that go from PL - RJ45 and ML - RJ45.
As well according to the Cat7/Class F New Installation Concept New Infrastructure Handbook the follow BeoNet cables exist and your dealer can most likely cross reference the part numbers if their not accurate anymore:
BeoNet product cable PL-RJ45
Part numbers:
6270017 1.5 m/4.5´ black
6270023 1.5 m/4.5´ white
6270020 3.0 m/9.75´ black
6270024 3.0 m/9.75´ white
6270004 5.0 m/16´ black
6270025 5.0 m/16´ white
6270022 10.0 m/32´ black
6270026 10.0 m/32´ white
BeoNet Product cable ML-RJ45.
Part numbers:
6270006 1.5m/4.5´ black
6270013 1.5m/4.5´ white
6270011 3.0m/9.75´ black
6270014 3.0/9.75´ white
6270002 5.0 m/16´ black
6270015 5.0 m/16´ white
6270012 10.0 m/32´ black
6270016 10.0 m/32´ white
Package size: 1 piece
