New software Beolab 50
Is there a section on the B&O website where I can check the change history and the current firmware for my Beolab 50s?
They only seem to be able to update the firmware when connected to the internet via ethernet, and they aren't connected via ethernet most of the time. It's frustrating that they can't seem to update via wifi.
I also wonder this as the BeoWiser BeoLab 50 First time setup video advices the installer to update the software first time manually via USB as the master unit will NOT update the slave unit if the firmware in the slave is lower than the master. It simply assumes that the slave has the same version as the master (which of course is a horrible design fault).
It seems that only B&O employees can download the firmware files as it is on an internal network page. I wonder if anyone here has the firmware available for the BeoLab 50s so I can update mine over USB when I receive them in a few days. As I have decided to do installation myself.
I also read that a few people here have different version on their respective speaker sets and that means this is an issue. Perhaps B&O has resolved it though in later iterations of the firmware so that the master does actually take into account a version conflict. But I do not know.
Michael wrote:
I also wonder this as the BeoWiser BeoLab 50 First time setup video advices the installer to update the software first time manually via USB as the master unit will NOT update the slave unit if the firmware in the slave is lower than the master. It simply assumes that the slave has the same version as the master (which of course is a horrible design fault). It seems that only B&O employees can download the firmware files as it is on an internal network page. I wonder if anyone here has the firmware available for the BeoLab 50s so I can update mine over USB when I receive them in a few days. As I have decided to do installation myself. I also read that a few people here have different version on their respective speaker sets and that means this is an issue. Perhaps B&O has resolved it though in later iterations of the firmware so that the master does actually take into account a version conflict. But I do not know.
Um. What BL50s are coming in a few days ?? 😉
Mine
I have just had my Beolab 50 installed and I have the latest firmware on both the master and slave, 2.3.3.7045 but webUi says 2018, guess that is still the same in the latest firmware.
2.3.4.7045 is the lastest, guessing it’s a type-o?
Mikipidia wrote:
2.3.4.7045 is the lastest, guessing it’s a type-o? New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
Mikipedia on YouTube (finally )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Yes, sorry. I have an issue already that my speakers won’t respond in the app or via web page. So I can’t change from narrow to wide. I guess I can pull the power plug and re plug them. Is this a common issue?
Are they wired or wifi? Wired will fix it, if wifi then I always had to double tap them to make the app work. But with eclipse or harmony it can also be done in the the speaker settings of the tv's menu, don't know about earlier tvs.
They are wired and it seems the app can’t contact them. I will power cycle later. Also noticed that sound disappears from the left speaker (slave) for a few seconds every now and then. Very odd. Perhaps like sound for 10 minutes, disappears for five seconds and comes back.
Anyone experienced this?
I have never noticed anything like that
