New SKY HD menu sound settings, where are they?
New menu comes when you get an updated Sky card.
Can't find sound controls on mine either!
New EPG will arrive as and when.  It's rolled out to all Thomson and Pace boxes already, most probably Samsung next,  then Amstrad.
There is now no longer any sound control from the EPG.
Hi there,
This works for my BV7 32.    USING the BEO 4 REMOTE
Switch from DTV to TV,  press the menu button,  under the tv setup menu press OPTIONS,  under this menu press SOUND, under this menu press ADJUSTMENT,  under this menu press VOLUME, and there you should be able to set your speaker levels.
REMEMBER TO ONLY PRESS THE " GO " BUTTON ONCE to go between menu's, and ONCE to exit and save.
Hope this all makes sense, and good luck.
MERCATS
