What are you using for the Audio Switch to switch the 3 inputs to your receiver?
I enjoy using iTunes, as with the iPad app I can select music, build playlists, etc. from the comfort of my listening couch and not have to get off my lazy backside. 😐
I have some serious issues with how iTunes organizes music though. It's not straightforward, due to the way it uses metadata. It has data in far more detail than I am interested in. For example, the album "Best of War" shows up under War and under the artists name, but doesn't show up as a single album in most views. I need/want simpler metadata, like only album title and group, I really could care less about who composed each song or filtering on that. I also am not interested in going thru the metadata by hand and cleaning it all up. This gets even worse on classical albums, are they cataloged by composer, orchestra, or conductor? There's not a lot of consistency either in how the metadata is setup for different albums.
But from what I can tell the Beosound 5 has the same issues, and no gapless play? Plus I have a lot of AAC iTunes songs bought off iTunes, DRM'd, that nothing else will play unless I convert them to wav and hand enter the metadata. Argh.
I am reworking the way I handle input switching and audio for the rest of the house. I'm not quite willing to pay what it costs to Beolink the house, going instead with an amp or two and in wall speakers and volume controls (autoformer based). Works OK, not as slick as Beolink, but a lot cheaper.
