You mentioned in a previous thread of a Beosound 8 XL.
Do you know if it will have Apple Airplay feature ?
Seem it will be an exciting 2011
The plan for 2011 included the release of 11 products. Out these, perhaps the BV11 will be the biggest surprise. Not sure if the 3D 85" is anything but a "we can do it, too"-type of product. The BV11 will feature the new digital video platform.
Roger
Is it a small tv or can we expect 40 inches too
yes you are right
but it would be nice if they had the same case
what´s about a hard disk for the DVB-HD-module? It was mentioned here very often, but still not available. It is very poor that it is not possible to record from the module in HD quality, only with the old HDR 1/2 in SD quality.
Regards
Räuber
It is very poor you have to pay to see hd in link room (atlona link system 25000-45000 ddk)
but is free to see analog in link room
You could always get a Key Digital HDMI splitter if you just want to "see" HD in a link room. I think you might be missing the point of the matrix though ... you should go check out a dealer that has it properly set up!
Roger
11?
Well they better hurry up. February is almost done and they have launched this year only one new product the beo6. That means that the rate of launches would be 1 per month...uhmm...really? If so great I love new product launches!!!
Hi Roger
Any idea when the BeoVision 11 and hopefully 55 "will be introduced?
Frank
