New product: BeoPlay EQ
I’ve just tried them. I like the fit and the sound was very good, but not as good as my Earpod Pros. The volume was ok but nothing special but the controls would absolutely drive me mad.
I spent 15 minutes trying to connect them to my iPhone, and in the end just used the shops IPad! I managed to advance the song once and then it didn’t work again. Turning the ANR on and off worked initially, and then rather comically randomly kept coming on and off throughout a song.
I’ve just tried them. I like the fit and finish over my Earpod Pros, but and although the sound was good it just wasn’t as good as those. Nor was the volume.
I spent 15 minutes trying unsuccessfully to contact them to my iPhone, and then just used the shops iPad.
The touch controls worked initially as I fast forwarded a song, but then didn’t work anymore. I managed to turn the ANR on and off but then it just kept working randomly throughout a song. Not a patch on the EarPod Pros I’m afraid.
I was using the H3 ANC before these EQ's and had the volume of the H3 just over half on my iPhone and it is way louder than the EQ at max.
I have noticed the odd comments people have made on instagram about all three generations of E8 having too low of volume as well due to B&O not wanting sacrifice sound quality or battery life.
I’ve a pair of E8s mk3 back in the UK. Only used them once!
Good review from Flossy
https://youtu.be/vrgY_xkULzQ
