@Bestwick8 besides black is a sand/beige colour that looks nice. The case for the black earbuds is a beautiful metallic dark brown.
New product: BeoPlay EQ
Is black the only color option ?
As far as known….what is the price?
https://news.yahoo.co.jp/articles/487a365d7ecc81b608ccd925cfc2f5cc423eaf33
Reviews are up, according to this site it'll be 39,900 yen, after converting over its pretty much the same regular price as the E8 3.0
Are you talking about the same brown/ beige like the HX in Timber ?
Bang & Olufsen, the first ANC complete wireless earphone "Beoplay EQ". Unique ear tips improve wearability
PHILE WEB 7/28 (Wed) 0:00
Bang & Olufsen will release the company's first fully wireless earphone "Beoplay EQ" with active noise canceling function from July 29th. The price is 39,900 yen (tax included). Wearing image Equipped with a feedback / forward active noise canceling function, used in combination with passive noise canceling that takes advantage of the airtightness of the earphone body. As a result, external noise can be insulated in a well-balanced manner, and Bang & Olufsen's signature sound can be experienced clearly. It also has a transparency (external sound capture) mode. Equipped with a φ6.8mm dynamic driver. Bluetooth supports version 5.2, and in addition to SBC / AAC, the codec supports apdX Adaptive, which is variable according to the communication status and optimizes sound quality. The maximum continuous playback time is 7.5 hours. The face plate is equipped with a touch control that allows you to perform operations such as noise canceling ON / OFF, play / stop, volume adjustment, and calling. The shape of the main body was designed with a focus on the fit to the ears and the beauty of the appearance. The silicon eartips, which were designed by repeatedly testing the length, depth, and position when worn, are said to provide a comfortable feel in various applications such as when moving and teleworking without getting tired even for a long time. There are 4 sizes, and Comply Sport earpieces (medium size) are also included. It is also assumed that the call quality has been improved by advanced beamforming technology. There are 6 built-in microphones, 2 of which function for transparency mode. The case supports Qi standard wireless charging and can charge earphones up to 2 times. The charging terminal is equipped with USB-C. Made of alumite-processed aluminum, it has a compact design and is easy to carry. Finished in an elegant color, he explains, "It is made with the idea of" aging "that you can enjoy aging so that you can use the scratches on the case."
Looks like less battery life for the case with only two additional charges
Looks like less battery life after translating that article, only 2 additional charges, so looking at 21-22 hours total.
Official release article
https://www.phileweb.com/sp/news/d-av/202107/28/53273.html
Google translate works quite well. You'll see the two colour schemes in the pics
I really don’t like that they seem to have made it more bulky with that protruding «fin» that presumably does things with ANC. Making it something other than round is like reintroducing the notch on a future iPhone that didn’t have it any more. But the charging case looks sweet.
