New product: BeoPlay EQ
The design is more reminiscent of the current H9, which also does not come with a box. Nor should there be the same type of DSP signal processing as the h95 comes with neither the titanium driver. Btw I don't think the h95 is intended as a product that will be permanently included in their product range. Personally I do not think we can expect to see them until sometime in March, although I would like to see them come out in the stores already here the 6th, but it is very unlikely and also not really related to the date we can find on fccid.io
Great finding! This is the real look of the earbuds. I can't disclose much more, but they are finishing the firmware.
So we can expect a release in the next coming months ?!
https://detail.tmall.com/item.htm?id=649926432281&ali_trackid=2:mm_25282911_3455987_109027850435:1627344539_299_396282305&union_lens=lensId:TAPI@1627344538@0b885a77_0d94_17ae54b09be_a030@01;linkRuleId:2;recoveryid:1627344539_299_396282305&ak=23340247&bxsign=tbkAeW4J9KjlP05KfKP5j4SD67JSr6gbxWduyu/B9AY5UP2c5e8QAQSNzQVdH92k6rPU4zIDBzzq9XjU3xG6aLahVmfEnrFzBR3dxB64WCIE4g=&sku_properties=5919063:6536025
Imminent Leak !
Out here in Qatar all the E8s in Virgin are massively discounted, so this will probably explain why.
The hardware is totally finished. I think the engineering team is still tweaking the firmware, as some tap gestures were not working yet. QI charge, good battery life, decent ANC... these are a nice pair of TWS
Is black the only color option ?
According to those Chinese websites, July 29 is release day for these ...
Bang & Olufsen, the first ANC complete wireless earphone "Beoplay EQ". Unique ear tips improve wearability
PHILE WEB 7/28 (Wed) 0:00
Bang & Olufsen will release the company's first fully wireless earphone "Beoplay EQ" with active noise canceling function from July 29th. The price is 39,900 yen (tax included). Wearing image Equipped with a feedback / forward active noise canceling function, used in combination with passive noise canceling that takes advantage of the airtightness of the earphone body. As a result, external noise can be insulated in a well-balanced manner, and Bang & Olufsen's signature sound can be experienced clearly. It also has a transparency (external sound capture) mode. Equipped with a φ6.8mm dynamic driver. Bluetooth supports version 5.2, and in addition to SBC / AAC, the codec supports apdX Adaptive, which is variable according to the communication status and optimizes sound quality. The maximum continuous playback time is 7.5 hours. The face plate is equipped with a touch control that allows you to perform operations such as noise canceling ON / OFF, play / stop, volume adjustment, and calling. The shape of the main body was designed with a focus on the fit to the ears and the beauty of the appearance. The silicon eartips, which were designed by repeatedly testing the length, depth, and position when worn, are said to provide a comfortable feel in various applications such as when moving and teleworking without getting tired even for a long time. There are 4 sizes, and Comply Sport earpieces (medium size) are also included. It is also assumed that the call quality has been improved by advanced beamforming technology. There are 6 built-in microphones, 2 of which function for transparency mode. The case supports Qi standard wireless charging and can charge earphones up to 2 times. The charging terminal is equipped with USB-C. Made of alumite-processed aluminum, it has a compact design and is easy to carry. Finished in an elegant color, he explains, "It is made with the idea of" aging "that you can enjoy aging so that you can use the scratches on the case."
Reviews coming in already ..
https://news.yahoo.co.jp/articles/487a365d7ecc81b608ccd925cfc2f5cc423eaf33
