When I had it connected to my iPad mini and I opened my phone, my phone would try and also connect causing disruption. I simply turned off the Bluetooth function.
Might helpπ€
Thanks, but unfortunately there wasn't any other devices trying to connect.. I've also experienced what you're saying though, but this is a different issue. Both are very irritating if you ask me.
I read in an extended review somewhere the A1 sounded best with the equalizer settings off (standard) so until now did not bother to play with them. But oh boy do i disagree om that remark !!! Lounge and dance sounds even better (a lot!) when dragging tye dot to the excited quarter. And RTFM TOO, you can also change the size with a pinch to optimize to your liking even more.
Depends what you're listening to I find. Sometimes it gets too boomy on that EQ.
