new masterlink
It will all depend on the distance. If you look at the ratings, the distance capabilities are fairly significant and probably far more than most would require in an average home. Now this is no guarantee (and we may well learn more details) but Cat6 should probably work. I'd definitely wait on any renovations before you've tested it!
Cat7/Class F Nyt installation koncept, ny infrastruktur
    håndbogen fra Bang & Olufsen kan du nu download.
Download pdf  file.
link
Mvh. Peter Pan
link
The new BV10 also has USB and Ethernet sockets at the back..😕
A question for the group:
Do you guys anticipate that the new BV-10 and the BV-7 55" will come with the necessary hardware to allow for future compatibility with this BeoNet?
Mark
Bad for me. We moved in our new house 5 months ago with ML wiring !!! Fortunately Ethernet as well. Don't know which one but'Ill find out tonight.
Could have saved money here......
Not so bad news... It looks like the Ethernet wiring cannot be shared with normal IP traffic anyway...
from my point of view it is just the old ML concept with Cat7 wiring and a central "junction box". Nothing else, nothing exciting.
Karsten
The new BeoLink-Digital, also known as the "BeoNet" will use standard RJ45 connectors, with Ethernet CAT 7 / Class F loop. It would distribute video and audio in analog and digital modes simultaneously with multi-sources in multi-room. BeoNet will allow the 1,000 meters in length Ethernet link wires and up to 300 meters for the Power Link cords. BeoNet allow open linkages with other non B & O network and domotic systems.
It is of course fully retro-compatible with the current Master Link-based equipment.
It is common sense to be this new B & O standard.
CAT-7 has now been ratified for STP (shielded twisted pair) cables with a bandwidth to handle Full HD video and analog / digital audio and high-speed broadband Internet connection, so it is likely that many of the existing systems will converge to this default.
For new installations, the benefits are enormous - Cord category offers reduced wiring, terminatation easy and simple integration with other products, including CCTV, internet, security, etc. The key to acceptance of the new system for existing Beo owners are expected to be a question about how easy (and expensive!) it will be adding the necessary to convert an existing Master Link system.
Most in the industry have worked with a question on this for some time now, with the result that you will soon begin to see a range of solutions for connecting new products from independent suppliers, the B & O Master Link is already in your home.
This is an exciting time for the B & O, since there is now potential for their products really can be integrated with other systems in a modern "high-end homes, and become the center of the product that makes the other" high-tech gadgets " useful in A / V system.
Greetings Peter Pan. Translated from Danish by Google
you are right Peter, BeoNet Cat7 cabling solutions will bring many benefits for people with B&O ML connected systems in their homes, are B&O still using Motama middleware ( NMM ) software to do this in 2010 ??
http://www.motama.com/nmm.html
and the UPnP AV server
http://www.motama.com/upnpav.html
Yes, I think. In 2007 started Motama and Bang & Olufsen a development cooperation BeoNet.
link
Greetings Peter Pan
link
