New LG Panels 2021 for Harmony, Eclipse and Contour
mbee wrote:
But as there is a chip shortage, I do not expect the new panels to be on time this year (usually around may). I'm waiting for the new LG HU810P/AU810P beamers but they have already been delayed for Europe. I expect the same for TVs.
It was similar for the GX launch last year. I picked up one of the first units in to the UK around early May 2020 as I was told there wouldn't be any more for another 3 weeks. Was scarce at launch. C1 will definitely be even harder to get hold of until almost Q3.
Any idea of the date G1 panels will be available on Eclipse gen 2 65" in Europe?
Yes, the G1 OLED evo is available both in 65" Eclipse and 65" Harmony. In 77" Harmony, you can also choose the Z9 (or the G1).
Will B&O make a Harmony to accompany a 55” screen size? I am guessing not but if they did, or do, I am ready to buy one. Anyone know?
The Speaker Boxes fit a 65", and the covers can then be 65" or bigger, to fit 77" and 88"
So they would not be able to make a 55" in the current version.
And the sales of bigger screens is the place to be.
So I would guess that it is not going to happen, ever.
If I were you I would consider a 65"
Thanks Emil. A 65” would just look to large and overpowering in my lounge I think. I could risk it but I think it would be overkill and design and minimalism is far more important to me. You want a home to flow, to work, to have good energy etc; not to be drawn straight to a large dominating tv that takes away from everything else.
Have a look at one, a 77” even sits ~10cm lower than a bv11-55 sits of the ground when it’s off. When they’re off they’re really not that dominant🙂
I could do Miki, no harm I guess. My current tv is an 11-46 so how do you think a 65" might compare to that? It's currently right up against the wall on a motorised stand even though I don't turn the stand.
So a bv11-46 on floorstand sits 108.7 cm of the ground & is 109.7 cm wide
a bv harmony 65'' sits 99.1cm of the ground when off & is 144.9 cm wide
and the bv harmony 77'' sits 115 cm of the ground when off & is 172.2 wide.
It's up to you and your room if that fits or not, I don't know your room. But to me this is the beauty of the harmony in that it's very unobtrusive when it's off even for very large sizes. and the difference between a 65'' screen and a 77'' screen is fairly substantial, it's has ~40% more screen size for only a 16cm higher tv when it's off. (while only being 6cm taller than your bv 11-46 which doesn't change height when on or off)
Measure it I would say and or send a picture so we can see what would and wouldn't work.🙂
