Hi All,
I'd like some opinion on where to go in terms of changing, adding to, or replacing my audio system. We're in the lucky position of building a new house around March next year and I'm very keen to achieve single remote nirvana and a multiple room system. So here are the questions, and I'll probably have to ask more because, as I browse the forums even more issues spring to mind!
Firstly, I have a Beosound 2300 with a pair of Lab 6000's, and I'm hoping to add another pair of active speakers for the Master Bedroom upstairs, with a Lab3500 as a link speaker in the dining/kitchen area. The house is contemporary in design which is great, but does raise a few issues with regard to speaker choice (single link or pair with control unit), and also placement. I hasten to add that I'm not an audiophile but love the quality of sound that B&O produces.
Audio is definitely a priority, and due to budget constraints we will definitely go for a generic flat screen with some sort of Lintronic control system, but I'm open to suggestions. My main priority is to be able to access a largish CD collection WITHOUT changing them all the time. I LOVE the 2300 for reasons others have posted but really need to save and store the discs. A prominent member has suggested Beosound 4, but I'm a little concerned about the quality even though I'm not an "audiophile". I'm not a technocrat and my only experience of this was to record a wma file from my Laptop to a disc which I then played on the 2300 and found it to be very "thin", for want of a better description! I probably used the wrong format or bit rate or something so again I'd welcome advice.
The initial questions are:
1 Wireless or Hard-Wired?
2 Beosound 4, Beosound 3200, BeoCenter 2 or other?
3 Speaker suggestions?
Many thanks in advance
Peter
edit - just added the BeoCenter 2 option as this may also be a solution
