Thank you Ken,
my Firmware is 7.05 you mean that 7.11 will fix it? So I don't need a switch from antenna socket with 2 cables to the BV7 right?
Thank you Ken,
I don't know the exact FW version numbers, but in my set-up Link-TV works with DVB-C signal. I was told that there were a probelm with this in prior FW versions, so I quit sure that is what you are seeing in your set-up.
Ken
