New DVB-HD dowload on B & O page
raveny wrote:
Edit:
I got it!!! Together with the USB stick and ethernet cable the BV7 updated to 0.1.66. Strange, isnt' it?
Confirmed: It is not possible to update your dvb-hd module on bv 7 without having ethernet plugged in. The tv simply does not look for the USB stick unless the ethernet is plugged in.
Haha...another FAILURE from B&O.
/Ehlerz
Ehlerz wrote:
That cant be true. You are not able to update the DVB-HD module through ethernet on a BV 7.
/Ehlers
There must be something wrong with my BV7-MKIV then, because I have updated the DVB-HD module software at least three times during the last couple of years, using only the Internet connection.
In the setup menu I can see if there is a new version and load it by pressing the green button.
It is easy to verify that I have this latest version, as the buttons are different with the blue one for update of the program overview.
Regards Ole
Installed this onto my BV10 on the weekend. No noticable difference, except that after about half an hour watching a channel, the screen goes grey, the old 'clock' makes a reappearance, the screen goes grey again, and eventually a picture reappears on a different channel - the one the television had been on when first turned on.
No such problem before the update. Surely more than coincidence?
Anyone else experience this problem?
I'm in Australia if that is relevant...
I had that problem with my bv10 as well. I was changing channels and the clock appeared and the tv froze so I had to turn it off then on again.
I have worse problems now though; after a burning smell the tv now doesn't work at all. Back to Service....
Peter
Oh dear...hope that's not next on the list for me!
Hello,
today firmware build 166 was installed on my BV 10-40 by my dealer. The HD module was updated to 0.1.6.6.0 last week by myself.
But the startup time of the HD module is still more than 30 seconds! Only if I switch on the TV directly after switch off it takes about 10 seconds. But if I wait a few minutes and then switch on the TV, it takes again more than 30 seconds.
I´m very disappointed!
Regards
Räuber
