New DVB-HD dowload on B & O page
Very happy with this update !! It fixed my problem where I couldn't rescan without having channels in two separate groups ( any single groups the tv would scan had either abc numbered wrong, or channel 7 upwards wrong). It (relatively) fixed a niggle I had had with the guide - that it wasn't populated unless I had first visited each channel - at least the update epg option on the guide page allows me to quickly populate the guide for each channel without leaving the guide.
I seem to be able to see more in the info page - I have a rating appear, and I'm sure something else (more text) but haven't been able to pin it down ..
Overall - very happy !!
Now if b&o could make the dvb-hd turn on quicker (as a free software update) I'd be ecstatic. Still a very happy beo owner though....
One other thing - why don't b&o give more info as to whats in the update? It would give people an opportunity to decide whether they want to chance an update ...
I realize that there are many countries they operate on - but assu ing that b&o know what they are fixing , it wouldn't kill them to communicate to the customer ....
Again, there's a new software available 0.1.6.6.0.
Now it takes 16 seconds to have a picture on BV10-40 with DVB-HD.
When I got my tv one year ago it took more than 44 seconds...!
With the latest software, I noticed that there's a bug after switching the mains off : when you start the tv for the first time after the mains off it takes more than 30 seconds to have a picture (and I sometimes see two B & O logo on the screen instead of one with an alterned quality).
Otherwise, after the first switch "on", it's 16 seconds again and that's great !
Gregory
has anyone tried to update via Ethernet? I have 1.6.5 but it can't find an update. USB stick doesn't work... I think it does not like my USB stick!
I had a problem with transferring an excel file on a stick ... eventually I reformatted the stick and it worked ... there must have been a bad sector on the stick !!!!
Hi
Is is not possible to update via ethernet.
This can only be done by USB.
/Ehlerz
I tried with two different USB sticks. It says OAD check, IP check all the time. Then I connected the TV with an ethernet cable and I got the message that there's no updates.
I formatted both sticks and copied the two files (.txt and .fpkg) from the zip to the root directory but nothing has changed.
Edit:
I got it!!! Together with the USB stick and ethernet cable the BV7 updated to 0.1.66. Strange, isnt' it?
Very strange, ethernet is only for Bluray update and BD live.
/Ehlerz
Not so. I have updated the DVB-HD module several times by using only the Ethernet connection.
Regards Ole
Hi Ole
That cant be true. You are not able to update the DVB-HD module through ethernet on a BV 7. Yor can however update your Bluray.
/Ehlers
