hi thorngaard thanks for responding i can't wait to see your pictures of your setup it sounds like you have a very good combination. i would also like to find out about your own opinions on the picture quality of the bv8-40 and how you feel the 100hz processing improves on the your viewing experience look forward to hearing your opinion and seeing your photos.
New BV8 40 - first impressions at home
doesn't suffer from any linkroom issues....
To be fair Moxxey, This is not true. You just dont have anything digital connected that needs processing by the BS3.. When doing this, the delay will be there for sure. That said, it does not justify the MKIV. I said a lot of positive things about this Tv, but i am to just about fed up with its issues. My dealer will update my DBV-HD module tomorrow. If this does not solve the numerous issues with the module, i will to return my tv..
How to access to this option (filmode) ? I use a beo4
Many thanks
2x menu. Go to "connections". RED and GO.
Thanks Zwaan, but in my case it doesn't work (red and go), any idea ?
Red and GO not at the same time. First RED and than GO.
Did you do that??
my steps:
- I swicht on the bv8
- 2 x Menu
- select options
-go connexions
- select red
- select go
- I have the same menu (AV1, AV2 ... , HDMI Expander)
If you don't select/activate "connexions" it should be oke. "You go to connexions but not activate this.
Strange.
Sorry Zwaan, it doesn't work.
