I do understand it also. It looks funny with a flatscreen 16:9 with black bars over and under the picture.
New, bigger TVs
And now Philips has announced a 21:9 screen ratio for TV's. That's good then, more 'must have' innovations!
Actually I understand that "standard", films are made in that format, not 16:9. So it makes sense to me.
Yes they are, I was just highlighting the fact that just when one level is reached, another comes along which necessitates TV replacement.
Might have helped if 21:9 had been adopted earlier instead of 16:9!
You are right, I for one, never understood the 16:9 format... Movies were never made in this format. I think it was judged upon our eyes field of view... (16:9)
But you know, at some point you have to think of something "new" to keep selling stuff.
Actually, I strongly suspect 16:9 was chosen as it was the halfway point (=compromise) between TV (=4:3, or 12:9 if you like) and Cinema (=2.39:1, or 21:9). So there is some kind of logic there. And, of course, content made recently for TV is 16:9, as are IMAX sections on eg Dark Night Blu-ray.
I've forgotten the actual reason, but believe it had something to do with backwards compatibility in digital video processing - i.e just a technical reason, nothing deeper in there.
Also, the choice was made long before flat panels became a commodity. 16:9 was already a hard aspect ratio to implement for CRTs, wider than that would've been just silly. Since the deflection angle doesn't get any bigger - I believe anything more than 110° was a curiosity - you can think the wide screen CRTs as just larger 4:3 tubes with sections cut off from each horizontal edge. Imagine the depth of a 42" 16:9 CRT, and people commonly have panels larger than that today!
I also heard about a 7-55. I guess it will be a LCD-screen ?
It would be good to see them come out with a plasma version of the 7-40 and future models but I doubt they would do that as I am sure the picture would look better on that size screen! I am sure cost has a lot to do with it too although I am sure there can't be too much in at when you are buying and manufacturing at their level of business.
Simon.
What do you guys think about the future ? LCD seems to take over more and more from plasma. If I buy a 4-65, will I be disappointed in a few yeards, not about the size of course, but the choiche of plasma. What is more exactly the differences between LCD and plasma by the way ?
Has anyone seen the 4-65 in action ?
Hans.
Halid,
If you consider the 65", i would wait a "little bit". Panasonic has just launched a new model of their 65" with industry-leading specs like 7000 grey-tones, 16 bit video-processing and a contrast-ratio of 60 000:1. A kuro-killer! (but it seems that kuro is going to oblivion anyway)! My guess is that B&O will adopt this panel but I dont know when..
Ahmet
If you become manufacturer of the best panels in the world (even if by default) would you sell them on to a competitor (albeit in a different market segment) or would you supply them with "last years" model and retain the "best plasma available" moniker for yourself🤔
I wonder how Panasonic might position themselves if Pioneer do pack in.
