All PIN coded items have a 5 (not 4) digit 'master code' associated with the serial number. Any dealer with access to the B&O community database can give you the 5 digit master unlock code. Up to them how when they do this. As long as it's not reported as stolen usually :-)
New Beovision...no pin :(
@Sal, i have BV10 and had it on motorized stand before. I can't speak for BV11 but i believe the set up visually is quite alike, the BV10 sits quite low on the motorized stand. Cable goes through the pole from the back side , just above the rotation plate. I had 3 cables in a black cable-sock running through it:-extension cord with 3-socket box (for DVD, ATV, STB, all mounted on the back)- power cable BV10- signal cable STBDepending on where your outlets are, you can install it super neatly. When BV10 was rotated at big angle I was more 'unhappy' with the 3 devices mounted on the back, rather than with cable management.Patience, persistence, cable socks and black ty-wraps can make a world of difference 😁 Login to view imageNew appartment, installation not neat (at that time) Login to view image
Ferdinand - I love the Miffy hug - and your tolerance as a parent !Congratulations once again on your "baby" - growing fast !
Thanks - and there is a 3rd one already (child) 😉The BV10 is now wall mounted, result the kids knocked the BL17 down from the cabinet it was standing on. I have ordered table stands so that the can stand horizontally@Ben SA, sorry for stealing your thread.
Thank goodness B&O products (for the most part) are built like tanks!
Not at all Ferdinand! The thread has evolved! 😁
