That's right. Announce them. And close the factory for the summer holidays.that we will see them just before the summer vacations start off.
New BeoVision
So, no Timber Vision ?
Precisely. Black back is cheaper than aluminum backIn the new price list Avants are priced in two specifications, with aluminum or steel back? I have no clue what that means but the aluminum seems more expensive. Perhaps it means that the wings (the aluminum plates on the back is replaced with either steel or just plastic on the cheaper model?).
No wooden TV's but what about the V1 replacement ?
No answer, I guess.....
Stay tuned - and you can't avoid having your answer.
Hoirt -Heard a rumor that there will be an AVANT MKII in June, that support HDR and Deep Color.
With that and an UHD Bluerayplayer, the picture should be as good as its gets.
Well no way as there's ZERO comparison between OLED and LCD for a TV. If you see the two side by side, you'll immediately see the difference. So wait until next years OLED offering if it's the ultimate picture that you are after.
Precisely.
Interesting. It is also a quite big difference in price (3000 Danish kroner, or 3700 Swedish kroner). I have the aluminum model, since it was the only one offered in the beginning - but the aluminum vibrates loudly when the internal subwoofer play loud noises. It's a bit annoying. Perhaps the plastic would work better but I guess it can be fixed with some furniture pads as well. But anyway I would probably have gone for plastic if the option was available back then. Aluminum looks sweet but it is on the back to be honest.
Precisely.
🙂 Agree. I rather meant as good as it gets with the LCD panel.
