New BeoSound Stage!
christiank wrote:
That's not clarifying. That's confusing. Has nothing to do with that app you're showing there.
Same interface, control over WLAN has been around for years!
BEOVOX141 wrote:
Just to clarify, There is nothing special here, the app has been around for a long time.
Karel refers to a B&O App installed on LG C9 (and future LG OLEDs), which, as with BeoVision Harmony, allows integration of the B&O soundbar and C9, to be used with BeoRemote One BT.
Exactly... If LG (and B&O) can update this app so that LG screens are out of the box able to communicate with the Stage (or future B&O products) then I'm confident that there is still a future for TV related products in the B&O gamma.
Karel.
Karel.
If LG let B&O touch their APP they are crazy.
Very nice design, great features, even Atmos, and comparable pricing to other premium sound bars. I really hope this sells well for B&O. I want to find a need for this in my house.
Why not choose the BeoVision eclipse in stead:) if you want 1 unit as you say, much more Nice then the canvas..
And eclipse can also more with the different motorisert placement, surround sound engine that allow you to upgrade with a subwoofer beolab 19, and full surround later:)
puc control that work perfect with all your connected black box (if you have one)
why choose canvas😂
People dont realy see what you Get in a eclipse, compared it to an normal flat TV. Sad:/
I’m not sure people don’t see what you get as much as they don’t place that much value in the features for the cost of obtaining them from B&O lately.
If you could point to the exceptional quality and rock solid, bug-free operation, you could possibly make a case. The software and operational quirks have let them down.
If the repair and service was able to quickly and cost effectively provide repairs, that would help, too. Recent products don’t seem to be easily or cost effectively repaired compared to the asking price of them.
I’m hoping the stage can win many hearts and new customers in ways that very expensive, but somewhat unreliable products simply cannot. Those that can afford those products also expect them to be worthwhile. Pretty, complex, expensive, and functionally challenged is not a winning combination.
I bought C8 last year and hopefully LG will be kind enough to offer support to upgrade the SW. I believe we are going to see a new center speaker with 5.1/7.1 connection, else it will be a missing link going forward.
BTW, what is PUC? 😳
Peripheral Unit Control - BV's have PUC ports for the Infra-red wire connecting your, for example, set top box / blu ray to the BV, to allow the BV remote to operate the set top box.   The set top box will also be connected to the BV by HDMI.
So 2 connections for each black box - one HDMI (picture/audio), one PUC cable (remote control signal path).
The new Stage doesn't have PUC capacity - it will rely on the HDMI cable to pass remote control commands, which is another way of doing the same thing, sort of.
Thank you for explaining. Still using my Logitech Harmony to control everything, but really looking to a future solution with Beoremote. :)
